Post by pagoda54 on Apr 22, 2018 16:52:51 GMT
Our 42i has a thick copper braid strap coming from the P-bracket - to the engine mountings. It is not in great condition- stiff and discoloured. How critical is this strap? The P bracket is bronze - with no direct contact to the shaft anyway. If it were isolated from the engine I can't see any great downside?? Any experience or comment on this strap from other boats? Replacing it would not be easy!
By the way, Flex-o-fold prop -no sign of any galvanic corrosion. Ditto shaft. Shaft anode lasted a season (as expected). The prop anode was part used up. The boat has a galvanic isolator
thanks, Graeme
Post by pbunning on Apr 22, 2018 19:52:32 GMT
There is no strap on my 33i. I wish there was. It is used, I guess, for cathodic protection - connecting the bracket to the engine block and so to the anode via the gearbox and shaft. On my boat. I have noticed a slight amount of de-zincification, which I have been monitoring over the last few years - not much, but there.
Post by pagoda54 on Apr 23, 2018 20:06:41 GMT
There is no strap on my 33i. I wish there was. It is used, I guess, for cathodic protection - connecting the bracket to the engine block and so to the anode via the gearbox and shaft. On my boat. I have noticed a slight amount of de-zincification, which I have been monitoring over the last few years - not much, but there. I decided on a typical "belt and braces" solution to the issue. I've added a pair of small clamshell style anodes to the P-bracket. Described as "trim-tab" anodes, about 50mm diameter- about 20mm thick each at their thickest. There is not that much P-bracket to be honest. There are thicker versions anyway- monitor until next winter. Required one 5mm hole and some loctite for fixing. I don't think I've compromised the P-bracket by one 5mm hole and I have some additional protection beyond the slightly dubious engine-P bracket strap.
Post by vasko on Apr 23, 2018 20:22:47 GMT
The connection is quite important just measure if the is connection between the p-bracket and the anides ... if not repair it
Erik
Jeanneau Model: Sun Odyssey 39i
Yacht Name: Miss Charlotte
Home Port: Port Washington, NY
Post by Erik on Mar 21, 2021 22:21:25 GMT
There is no strap on my 33i. I wish there was. It is used, I guess, for cathodic protection - connecting the bracket to the engine block and so to the anode via the gearbox and shaft. On my boat. I have noticed a slight amount of de-zincification, which I have been monitoring over the last few years - not much, but there. I decided on a typical "belt and braces" solution to the issue. I've added a pair of small clamshell style anodes to the P-bracket. Described as "trim-tab" anodes, about 50mm diameter- about 20mm thick each at their thickest. There is not that much P-bracket to be honest. There are thicker versions anyway- monitor until next winter. Required one 5mm hole and some loctite for fixing. I don't think I've compromised the P-bracket by one 5mm hole and I have some additional protection beyond the slightly dubious engine-P bracket strap. Pagoda54 - I have the same issue with the copper braid on my Jeanneau 39i that many others have had, so I am planning to install a trim-tab type clamshell anode. May I ask if you through bolted the clamshell by drilling a hole straight through the P-bracket, or did you drill a pilot hole to screw the clamshell directly into the P-bracket? I'm assuming you did the former. How difficult was it to drill through the P-bracket? (I don't think I've ever drilled into bronze before. Thanks, Erik
Post by andreshs1 on Mar 22, 2021 7:42:30 GMT
Hi all
very interested to see an actual photo of the final installation
cheers Andres
